Shower Fixture Change - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2010, 02:40 PM   #1
shower fixture change
I'm re-doing a bath/shower combo. It currently has separate hot cold faucet handles. So when taking a shower, one has to add a little of this, a little of that, before finding a good temp.
How big of a task is it to change that to one handle that manages hot and cold (and all inbetween)...? DIY or serious plumbing job?
locam is offline   Reply With Quote
Old 05-24-2010, 05:12 PM   #2
OK, I have better terminology now. I'm looking to go from a triple-control mechanism (one handle for hot, one handle for cold, one handle for shower/tub spout)
to a single-control fixture.
Is this a pretty big deal, or a DIY?
Old 05-24-2010, 09:31 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Whether its a DIY project or time to call in a professional is relative to how experienced you are with plumbing. You're going to need to get into the wall, cut out the existing valve, solder in a new single handle, pressure balanced valve, patch the hole, then install the trim. If you can solder in close quarters and have the proper tools its not too bad. If your experience with plumbing is slim to none....weeelll....thats another story.
JDC is offline   Reply With Quote
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Problems replacing old shower fixture teawhy Plumbing 1 10-22-2009 01:26 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Tub and shower fixture replacement golfer2b Plumbing 5 03-10-2008 04:06 PM
