Shower Faucette Leaking - Trouble Removing Spindle - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2013, 08:37 PM   #1
Shower faucette leaking - trouble removing spindle
Hi all,
I have a Symmons temptrol shower faucette that is leaking. I did an internet search, and found this video that talked about replacing the spindle.
My shower assembly looks exactly the same as in the video. I got to the part of the video that it is at 1:10 in. Removing the spindle. It was very difficult to start to remove. I finally got it to budge, and thought I was going to be home free. However, it never got easier. Now, it has a whole half turn that it will go easily either way, but is not any easier to come off. It seems like something is wrong to me. It looks like there is a black washer along the thread that it is turning on that might be binding on? Should I just continue struggling with it until I eventually get it off? I just don't want to ruin anything. Something doesn't seem right. Thanks for any advice anyone can provide.
jake14mw is offline   Reply With Quote
Old 03-26-2013, 08:50 PM   #2
Rewards Points: 144
Is it lose enough to turn by hand? (ccw), if so, sounds like u got it lose enough should just jiggle and pull right out. Some can b sticky.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
jake14mw (03-26-2013)
Old 03-26-2013, 08:51 PM   #3
Rewards Points: 6
Before you started to remove the spindle, did you open the valve (like you would to turn on the water). The black washer isn't very thick so if it's turning it's not binding. When it starts to get touch, screw it back in a little then try to remove it again. You can also try a little oil on the threads.
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 03-26-2013, 09:41 PM   #4
Thank you both very much for your help. Your responses gave me the confidence to keep going with it. I took the advice, opened the valve and oiled the threads. I got it out! Thanks!
Now the next problem. The only thing I replaced was the spindle. When I got it back together and tried it, the range of motion is very small. It only goes a quarter turn now, and I get no hot water at all. Any ideas what I might have done wrong? Thanks again.
Old 03-26-2013, 09:48 PM   #5
Rewards Points: 6
You probably need to adjust the hot limit screw. It's the small screw on the spindle. Turn the screw counterclockwise a bunch of times. Turn the water to the hottest temp you want then turn the screw back in. Very important if you have small children.
Dan
Old 03-26-2013, 09:52 PM   #6
Rewards Points: 144
U can try this, see if it helps. It was attached to your video.
shut offs to shower wide open? the spindle has a pressure balancing valve,it could be stuck letting more cold water in.Before you change the spindle check the little brass screw in the spindle housing.If you stop my video a 1:00 you can see it. that screw is used to control the temp. Screwed in it keeps the temp cooler screwed out it should get warmer in temp be careful not to go too far as it will get hot like your facets. Go a little bit and try it and repeat. let me know if it solved it.
Old 03-26-2013, 10:13 PM   #7
Thanks very much to both of you. You were right, that was the problem. I am back up and running now! It sure is lucky for people like me that people like you take the time to help others. I really appreciated it.
Old 03-26-2013, 10:26 PM   #8
Rewards Points: 144
Your welcome. Glad it worked out for u.
Old 03-26-2013, 10:41 PM   #9
Roofmaster
Rewards Points: 2,172
Good Job Guys, I thought it didn't work because it was French. "Faucette"?
Old 03-26-2013, 10:44 PM   #10
Rewards Points: 144
Roger that Jagans lol
Old 03-26-2013, 10:47 PM   #11
Rewards Points: 144
Good job. Well done.
leaking - tiled shower stall jbeazer908 Tiling, ceramics, marble 4 07-07-2012 06:59 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
shower faucet valve leaking throne7 General DIY Discussions 6 03-13-2010 07:31 AM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 01:08 PM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 10:50 PM
