Shower Faucet Replacement - PVC Replacing Steel? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2008, 11:50 PM   #1
Grizzled DIYer
Shower faucet replacement - PVC replacing steel?
Hello and thanks in advance for your input on this post.
Replacing a tub/shower unit and all fixtures/hardware with a two-piece Lasco unit and American Standard faucet. Unit itself went in very well, mounted and done and drain/overflow are connected and complete.
The question...
Is it necessary to convert the PVC and CPVC supply lines (coming thru subfloor from the crawlspace) to galvanized or copper pipe before the faucet? The existing shower tree was all galvanized pipe which has scaled up inside very badly in the 12-13 years it has been in use.
No filtration on our well and the water isn't the best - most likely causes of the buildup and subsequent pressure and flow loss is the galv pipe. From the PVC supply lines, pressure is good to the shower.
Obviously there is a good reason for using copper or steel in the last section before the faucet, and for the shower riser. What is the trouble with using PVC and CPVC right to the fixture? I am assuming a weakness issue, esp with female plastic fittings, yes?
If mounted, supported and clamped properly, will PVC/CPVC be problematic?
Any input is welcome and appreciated.
jdm1 is offline   Reply With Quote
Old 11-29-2008, 01:53 AM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
You can use CPVC for the waterlines on your shower. Just be sure to do like you said and clamp everything well. Personally, I'd change it over to copper but there's nothing at all wrong with CPVC. You also mentioned PVC which is not supposed to be used for waterlines inside a house. Stick with the CPVC and you'll be fine.
JDC is offline   Reply With Quote
Old 11-29-2008, 11:38 AM   #3
OK - I will transition the PVC to CPVC in the crawlspace and pipe with CPVC inside. The original tree has PVC on the cold up the wall to the galvanized and CPVC on the hot. Thanks.
jdmensing is offline   Reply With Quote
Shower faucet problem PlainlyJane Plumbing 16 09-06-2009 07:43 AM
Replacement shower faucet? jlajla24 Plumbing 4 11-24-2008 05:17 PM
Faucet replacement rondo Plumbing 2 12-03-2006 12:49 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 12:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 10:36 PM
