-   -   Shower faucet problems (http://www.diychatroom.com/f7/shower-faucet-problems-32611/)
Dmaxmama 11-25-2008 05:45 PM
We had a dripping showerhead that was driving me crazy! First we tried replacing the shower head, that didn't fix the problem. Then we replaced the cartridge, bonnet, water temp handle, and the knob that turns the shower on. No leaks, so we are on the right track. This was a Mixit faucet, which is now made by Danco. The problem is, the temp. control handle moves much too freely! Even turning the water on or off moves the handle from freezing to scalding hot. We got conflicting directions from the manufacturer and the hardwarw store on the orientation of the cartridge? Can it be just rotating 180 degrees will fix the problem?
DangerMouse 11-27-2008 07:22 PM
Originally Posted by lyjg1126 (Post 190865)
独享带宽 顾名思义即托管用户独自享用一部分机房带宽资源。它适用于有较大规模的数据流量和访问量,对带宽资源要求保 持恒定速率或有特殊要求的网站,如较大规模的ICP服务商、视频音乐网站、以商业运营为目的的网站等。大、 中型托管业务中,客户对带宽有较高的要求,其网站的内容和性质决定只有使用独立的带宽资源才能满足品质的需 求,而这种只给单独客户使用的带宽资源称为独享带宽 。独享带宽的收费方式区别于共享带宽,是两类的结合体,第一类是服务器所占用机架空间的机位费用,第二是独 享带宽的费用,分门别类地计算机位费和带宽费。 使用独享带宽 ,整个带宽资源归属于一个客户,所以是按照独享带宽的最高值进行收费,而不在于客户的实际使用量。如:一个 客户包一个机架另加100M独享的带宽,那么哪怕这个客户所包的机架里只放了一台服务器,而这台服务器哪怕 只使用了1M的带宽,那么这个客户还是必须按照一个机架的机位费和100M独享带宽的带宽费来 全额支付。独享带宽 的优点是可自由使用带宽量,能保证速度和网络质量;而缺点则是费用昂贵,一般100M的独享带宽 ,每月费用从上万到数万不等,这种方式不是所有客户都能接受的。
dang! you'd think satan would give you spammers a day off for the holiday..... guess not.
DM
