Shower Faucet Continues Leaking After... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2014, 05:43 PM   #1
Shower faucet continues leaking after...
Hello all,
I have a shower faucet that is leaking cold water.
I have replaced the stem, replaced the seat, used flat and rounded washers, even tried teflon tape in the threads of the stem.
It continues leaking all the same.
Any ideas?
crossnote is offline   Reply With Quote
Old 05-09-2014, 06:35 PM   #2
Rewards Points: 14
If you used the exact correct replacement parts and still have a leak, replace the faucet.
SHR Plumber is offline   Reply With Quote
The Following User Says Thank You to SHR Plumber For This Useful Post:
crossnote (05-09-2014)
Old 05-09-2014, 07:23 PM   #3
I was hoping for an alternative than having to rip up the shower tile.
Old 05-09-2014, 07:58 PM   #4
The stem part wasn't exact, the New is PF China the old one is PF USA.
Would that make any difference?
Old 05-09-2014, 08:26 PM   #5
Rewards Points: 14
As long as the replacement parts are Pfister brand original manufacturer it should not leak. Did you use generics such as Danco brand from a big-box store? If so, replace with quality original Pfister or USA made generic.
Old 05-09-2014, 08:56 PM   #6
The new ones were Price Pfister made in China with a Lasco sub brand name, bought at an Ace Hardware
Old 05-09-2014, 10:37 PM   #7
What original Price Pfister stem would correspond to this Lasco S-1119-3 6123?
I'll try to hunt down the original Price Pfister part but I don't know it's part #.
Old 05-09-2014, 11:13 PM   #8
Rewards Points: 14
The Lasco parts are junk but if it has a good washer on it there should not be a leak. Be sure to replace the washer and seat on the hot side too. In my experience the seat is usually the bad part if a DIY or handyman stem repair still leaks after replacing both washers. You did replace the seat, right?
crossnote (05-10-2014)
Old 05-10-2014, 12:54 AM   #9
I replaced the seat on the cold side only, the hardware store ran out of more seats.
Old 05-10-2014, 05:22 PM   #10
Problem fixed.
A retired plumber came by and slapped some teflon on the threads to the seat.
Old 05-10-2014, 05:47 PM   #11
Rewards Points: 14
Great!
Old 05-10-2014, 05:50 PM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,434
Thanks CrossNote.... A lot of guys forget to come back and tell/explain the solution....
MTN REMODEL LLC is offline   Reply With Quote
Shower faucet leaks into tub and behind the wall safetybar Plumbing 8 04-13-2014 05:35 PM
Leaking shower Floor Repair Skepticsteve68 Plumbing 1 02-16-2014 12:24 PM
shower mixing value capping off faucet quetion vote4Pedro Plumbing 1 06-28-2011 04:12 PM
picking a shower faucet vote4Pedro Plumbing 7 05-27-2011 09:56 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 07:16 PM
