Shower Drips! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2007, 06:40 PM   #1
Shower drips!
Hi,
My husband and I just redid our bathroom. We ran pex lines from a manabloc system to the shower and tub (hot and cold lines).
The problem is this: everytime I turn the faucet on to have a bath, water starts dripping out of the showerhead (at a pretty decent speed) at the same time. It's not a full-bore shower spray, but it is still a significant flow. This gets water everywhere. The knob that you would normally pull up to start the shower is down, so that's not the problem. I can't figure out why this would be happening, and also how to fix it.
Any ideas?
M
Monty is offline   Reply With Quote
Old 11-29-2007, 07:12 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Did you use copper pipe riser for the shower head?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 11-29-2007, 07:24 PM   #3
Hi Ron,
No we didn't use copper, we used pex line
Old 11-29-2007, 07:30 PM   #4
Journeyman Plumber
Did you use pex to the tub spout?
Old 11-29-2007, 08:05 PM   #5
ICF Construction
Hey, I ran into this once before, if it's Kohler, check page 3 of the install manual, do not use pex for the spout. I take it this is what you were getting at Ron?
Chris
Chris Johnson is offline   Reply With Quote
Old 11-29-2007, 08:19 PM   #6
yes we did
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 08:23 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
