Shower Drain... What Exactly Do I Have Here? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2009, 02:06 PM   #1
Shower Drain... What exactly do I have here?
Doing a full bath remodel, and tore out the old, tired 1979 fiberglass shower stall and found an odd-ball drain assembly, that I was hoping someone could help me out with... There is a 1' x 1' square hole cut in the concrete foundation, that drops in to an 18" deep plastic-lined box (think it's PVC). The box is completely surrounded by additional concrete, that looks to be a part of the foundation. The drain pipe assembly (PVC), including the elbow is fully enclosed in the box, and exits one side to the main sewer line (so I have access to the pipe). Additionally, the plastic liner box is filled with about 4" of dirt (and various other scraps and trash that the original builders decided to throw in there). Anybody have any idea what this is? The closest thing I could find on the web was a "French Drain", but those are primarily used in basements and seem to be a bit different than what I have.
On to my concern... I've purchased a tile-ready shower liner, and when I drop it in place, I can feel slight compression movement in it at the location of the 1' x 1' hole when I put weight on it. Any movement of the liner will cause the grout to crack in my tile floor, and I obviously don't want that. I tried creating a brace with a 2x4 that I wedged into the hole, and covered in RedGuard, but there's still movement. My next thought was to try just filling the "hole" with some form of cement, and levelling it to the rest of the floor. Would this work? Any other suggestions?
Thanks a lot!
Vern is offline   Reply With Quote
Old 03-20-2009, 03:41 PM   #2
That is simply a tub box put around the drain stub-up prior to pouring the slab. It is to keep the concrete from around the drain so the tub drain can be hooked up later. It is normally filled with whatever fill dirt is available on site at the time. Yes, it can now be filled with concrete to fill the void.
porchmonkey is offline   Reply With Quote
Old 03-21-2009, 12:10 PM   #3
Thanks a lot PM! I had another idea... rather than pouring cement in there, and permanently blocking access to the drain pipe, what about pouring in sand to fill the void (and maybe a little water settle it)?
Old 03-21-2009, 12:15 PM   #4
knowsomethings
If you are tileing the floor of the shower you will need a solid, non moving surface or you WILL have problems with the tile/grout cracking from movement. Concrete it in (wrap all pipes with plastic or proper tape if they are plastic). If done right you will have no reason in the foreseeable future to have to bust up the concrete around the drain.
Greg
runout is offline   Reply With Quote
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
