Old 10-19-2012, 02:44 PM   #16
Shower Drain W/O P Trap Help!!!
I guess so, mine had sand under the foundation so I just reused that and added some more to it.
pwgsx is offline   Reply With Quote
Old 10-19-2012, 07:18 PM   #17
Super Moderator
I always use PVC---easiest to mate up with the PVC drain set----
Pack the pipe in gravel---you will have plenty from digging around the old pipe--
Replace the concrete with your deck mud as you form the pan--
This gives you one more chance to adjust the drain set for a level cover---
Make sure that pipe is plumb----crooked will make the drain out of whack to your tile.
Use a square drain cover--
A Latacrete or Schluter drain will not require the 'divot' or the filling---but will cost $125 instead of the $36 that a membrane drain with a square cover will set you back---
Old 10-19-2012, 07:22 PM   #18
Super Moderator
And --yes---I was poking at you for trying to avoid the P-trap job---You would have ended up doing it any way after you figured out that no drain cover set would mate up with the old pipe---
And yes---a hand maul will break that out---I own a jack hammer---so---------------
Old 10-20-2012, 12:08 AM   #19
"You can do anything"-Mom
brockmiera's Avatar
So should I break out all the concrete in the pan or just what I need to reach the trap? also do I use the glue on fittings or screw on fittings?
Sent from my SGH-T959V using DIY Chatroom
brockmiera is offline   Reply With Quote
Old 10-20-2012, 07:12 AM   #20
Super Moderator
Only open the area that you need in order to replace the drain---
Glue up fittings--except the rubber boot--
Use Sackcrete to replace the concrete if the hole is large---block out the drain area so that the drain pipe is still able to be wiggled--I usually leave an opening around the pipe about 7 inches square---then pack that as I build the pan
Old 11-16-2012, 12:49 PM   #21
brockmiera's Avatar
So my girlfriend thinks that WE might want a tub down there instead of a large shower. If I were to plumb it for a tub would I have to then pour a pad level with the rest of the basement in order to support the tub?
HELP! Broken Shower drain connection to ABS Trap megablok Plumbing 32 04-22-2012 09:13 PM
I have a floor drain that does not line up with the shower stall and there is no trap. Daddy6h Plumbing 2 11-02-2011 10:42 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
