Old 10-19-2005, 07:45 PM   #1
Shower Drain/Vent
I am trying to route a drain and vent line for a new shower in my bathroom addition. The shower is located next to an exterior wall and the main sewer line enters the addition approx 2 feet away from the addition.
I would like to come up from the main sewer line with a 4x4x2 vertical sanitary tee. Another 2x2x2 sanitary tee would be approx 1 foot above the sewer line. The tee portion would pick up the shower drain/trap. The other portion would continue up into the exterior wall above for the vent. See attached drawing. Is this an acceptable way to drain a shower?
Thanks!
handyman923 is offline   Reply With Quote
Old 10-19-2005, 08:14 PM   #2
Shower Drain/Vent
Thanks!
You do not show distances. If the weir(90) of the trap is within 6' of the sanitary tee and the stand pipe out of the 2" trap is less than a 20" riser...you should be fine.
plumguy is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 09:23 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
