Shower Drain Route - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2010, 07:57 PM   #1
shower drain route
I am installing a bathroom in my basement. My layout has the shower lined up so that the drain will be between the main connection to the sewer and the street. Therefore I would have to backtrack and run the shower drain parallel to the current drain and insert a 90 elbow to get it to the house drain. My question is, as long as it is sloped properly, is there any reason to not install a 90 elbow in the run? Thanks.
beech is offline   Reply With Quote
Old 12-01-2010, 09:04 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 538
90's come in three paterns: short sweep, medium sweep and long sweep. Also called short, med., and long turn. In your case (laid on its side in the horizontal) you want a long sweep 90. You can also use 2 45's glued together to make a 90. These will give you the long sweeping pattern the inspector will look for
The Following User Says Thank You to TheEplumber For This Useful Post:
beech (12-02-2010)
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Solution for 1.25" drain pipe for removable shower? CZ DIY Plumbing 3 10-06-2009 10:20 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 10:06 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
