Shower Drain Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2011, 08:59 PM   #1
Question
shower drain rough in
I am remodeling a bathroom that already has a tub, toilet and sink. I am adding a shower that is completely separate from the tub. I would like to know how to do the rough in. My question is what size of drain line is required and what size of vent pipe do I need for the shower. The new shower i going where the old sink was so I am hoping that the vent (drain) that went to the sink will work for the shower.
Also, assuming a p-trap is required is there any problem with it being immediately below the drain as the line needs to fit in less than 9 inches as it will be in the second floor, floor joist.
Bill
bhisley is offline   Reply With Quote
Old 02-19-2011, 09:40 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
2".
XXX
Old 02-19-2011, 10:01 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Bill
You need a 2" drain line for your shower, and an 1-1/2" vent. You can put the p-trap as close to the drain fitting as needed. I'm confused where you say "I am hoping that the vent (drain) that went to the sink will work for the shower." Are you talking about the drain or the vent here?
Journeyman Plumber
Old 02-19-2011, 10:41 PM   #4
Sink Drain
The drain for the sink currently goes across the wall to the vent pipe and tees into it at about 40 inches (well above the floor). Does the shower drain need to tie into that vent somehow?
Old 02-20-2011, 01:43 AM   #5
Doing it myself
Alan's Avatar
If you are eliminating the lavatory at that location you can cut out the tee, tie the 1-1/2" drain into the 1-1/2" vent as if the tee were never there, and then use the portion below the floor to vent the shower drain.
Journeyman Plumber
Old 02-20-2011, 08:05 PM   #6
Thumbs up
Thank You
Appreciate the help. I think I have it now. It took me a while to get my head around the purpose of the vent and how it works. Thanks.
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 10:08 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
1 1/2" shower drain tlynn Plumbing 3 02-25-2010 05:09 PM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 02:00 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
