Shower Drain Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2012, 05:39 PM   #1
Joe F's Avatar
Rewards Points: 294
Shower drain removal
I'd like to replace the drain fitting in my fiberglass shower pan since the drain cover screw holes have broken. Looking down into the drain, it appears to be a threaded fitting. Is there a special tool or technique to remove it? I tried to tap it with a hammer and screwdriver, but it didn't want to seem to move. I didn't want to hit it too hard because I'd rather not "bugger" it up until I have the new one in hand (I was going to take the old one with me to the supply house to make sure I get the right part).
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 04-13-2012, 07:39 PM   #2
DIY staff
Rewards Points: 7,174
That drain is held in with a big nut under the pan---you must remove that from below---
The drain looks like a kitchen sink strainer basket--
Old 04-13-2012, 08:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 350
Mikes spot on. If you can't get to the nut below you might sear hi & low for a snap in retro fit grate.
Old 04-14-2012, 06:42 AM   #4
Joe F's Avatar
Rewards Points: 294
It's a little tight, but I can get to it from below. The fitting on the bottom is glued to the tail and trap, so looks like I'll have to cut out a section. Thanks.
The Following User Says Thank You to Joe F For This Useful Post:
oh'mike (04-14-2012)
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 08:27 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
shower drain removal andrewc1414 Plumbing 0 05-05-2010 12:54 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
