Shower Drain Relocate - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2008, 08:57 PM   #1
Question
Shower drain relocate
This being my first post I am a little nervous, but here goes.
My son had a sewer backup in his basement. The damage was covered by insurance. The basement bathroom was gutted by the restoration company. There was an existing shower stall which was removed. This was a very cheap plastic unit which was not worth reinstalling. My son decided to purchase a new corner unit from Home Depot. Now it seems that the drain for the new shower is located 12 inches from both corners.
The old unit was 16 inches from the corners. I figure that the concrete will have to be dug up and the drain(ABS) relocated.
Here lies the problem.
The original concrete floor has been patched over the drain pipe from the toilet which runs along the wall about 12 to the centre of the pipe. This is where we will have to relocate the drain for the new shower. I want to tear up as little concrete as necessary to do this job. Is there some kind of flexible pipe or offset that will make this job easy?
fireman74 is offline   Reply With Quote
Old 12-28-2008, 10:53 PM   #2
Registered User
Termite's Avatar
Welcome to DIY Chatroom. No need to be nervous, we're a friendly group.
Yes, you'll need to break up a little concrete to do this. There are no flexible options unfortunately. Where the old drain is located there is a trap in the concrete floor, and that trap will need to be moved to the new location. You can rent a small chipping hammer (mini jackhammer) to make the job a little easier.
Old 12-29-2008, 08:05 AM   #3
Thanks thekctermite.
I am heading out to rent a small jack hammer. I just hope that I don't have to move the large (3 or 4") drain pipe that runs horizontally under the floor. If I find that it is in the way of the required location of the 2" shower drain/trap, I will call a pro and have him do this. I can at least rip up the concrete.
Old 12-29-2008, 11:46 PM   #4
Registered User
Termite's Avatar
Just shoot a picture of what you find and we'll work on a solution with you.
Relocate shower drain in concrete devouru Plumbing 16 10-03-2015 02:56 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
