-   -   Shower drain question, (http://www.diychatroom.com/f7/shower-drain-question-2660/)
diy'r 06-04-2006 02:34 PM
I am not sure about the drain plumbing on my new shower. The original contractor put the drain in the wrong location. In order to move the drain to the correct location the new contractor busted concrete and put another p-trap on the line and swivelled it into the correct location.
Is it ok to have 2 p-traps in a series?
The line is 2" and dumps directly into a 4" main line.
manhattan42 06-04-2006 04:17 PM
Code Violation
It is a code violation to double trap a fixture.
One of the traps needs to be removed
diy'r 06-04-2006 07:50 PM
Thanks, That's what I needed to know.
sandy7284 11-14-2006 08:15 AM
is it against code to not have a p-trap in your shower drain. i had a bath installed in basement with a sump pump . sometimes i have a smell. wonder if the contractor actually put in p-trap. one plumber says its not there. how do i tell.
Ron The Plumber 11-14-2006 08:29 AM
All fixtures are required by code to have a trap, no trap means gases in your home.
Shine a flash light down the shower drain is you see water you have a trap, no water, chance there is no trap.
sandy7284 11-14-2006 08:48 AM
ron, so if there is water in the drain, i can assume there is a p-trap, right? I am about to have the shower tiled and don't want to have problems later and have to dig it up. I have heard that with a drain in the floor and a sump pump that you have to run water in it occasionally or it will smell a little . Is that right?
I had the bath put in a long time ago and just never had it finished out.
and sometimes I notice a smell if I dont run water in the drain.
Ron The Plumber 11-14-2006 02:30 PM
Yes you can assume there is a trap there.
Yes you need to make sure water keeps the trap seal, add water once in awhile.
