Shower Drain Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2012, 10:41 AM   #1
shower drain plumbing
I took out a garden tub and put in a walk in shower. The drain had to be moved from the corner to the center for the shower. I just extended the pvc over and centered the drain and used a p trap like the other drain had. I tested the drain before installing the shower pan and tiling the shower. It seemed to drain fine. However, I did not run a large volume of water through it. Now that the shower is finished, about half way through the first shower, the water started backing up. I used a shop vac to make sure that the drain was clear and it is. Do you think I have a venting or correct pitch on the drain pipe problem?
Arrrgh! is offline   Reply With Quote
Old 04-07-2012, 12:56 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Hard to say without seeing your work.
You say you took out a tub and put in a shower. Did you upsize the drain? Showers require a 2" drain and there is a reason for this.
Journeyman Plumber
Old 04-07-2012, 01:05 PM   #3
what alan said. did you also put in body sprays or huge shower heads>
Old 04-07-2012, 08:35 PM   #4
Thanks for replying. I will have to look at my pvc. I think I kept 1 1/2 " tubing and it connected to my drain without a problem. I will try to download a picture that I took of my work before I put in the shower pan system. My wife is pretty mad because I will have to cut out a section of the foyer ceiling for access. At least I do have access!
Old 04-07-2012, 08:39 PM   #5
One more thing
In response to Danny T. I just have a standard shower head. It is a delta wide spray head. No body sprays.
Old 04-07-2012, 08:40 PM   #6
DIY staff
Rewards Points: 7,174
Pictures will help---Opening the ceiling isn't the end of the world---good luck--
Old 04-07-2012, 08:53 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
You didn't wash any grout down the drain did you? Thar's a quick way to plug a drain- it hardens and your shop vac won't remove it
Old 04-07-2012, 08:53 PM   #8
Homerepairguy's Avatar
Rewards Points: 990
I'm looking for a couple of good shower heads. How do you like your Delta wide spray head? Is the spray strong or like from a flower watering pot? If you like it, what model is it?
Thanks,
HRG
Homerepairguy is offline   Reply With Quote
Old 04-07-2012, 09:23 PM   #9
Doing it myself
Alan's Avatar
Thanks,
HRG
I like this one. Have one on all my showers. Nice and big, but still plenty of pressure behind it.
http://www.us.kohler.com/onlinecatal...e=0-2131042038
Journeyman Plumber
Old 04-07-2012, 09:23 PM   #10
Doing it myself
Alan's Avatar
What kind of shower drain did you use?
Journeyman Plumber
Old 04-07-2012, 10:02 PM   #11
Rewards Points: 990
I was considering that shower head until I read this review on amazon:
"The experience of this shower head can best be described as standing under a garden watering can, that's about to run out of water. The pressure is very weak and the streams are hair thin. I figured the flow reducer inside might be partly to blame, so I proceeded to take it out (which took 15 minutes in a tool shop, because unlike with most shower heads, the reducer in this one is really difficult to remove. It finally came out in pieces.) Unfortunately, it still did not improve the water flow or pressure by any meaningful amount. It appears the internal design of this shower head just does not permit a lot of water to go through it."
I wonder if that poster just didn't have enough water pressure?
Thanks,
HRG
Old 04-07-2012, 10:29 PM   #12
Rewards Points: 636
irc sizing states a 1 1/2 trap will drain up to 5.7 g.p.m.
http://publicecodes.citation.com/ico...2_7_sec009.htm
there is something else going on
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-07-2012, 10:31 PM   #13
Doing it myself
Alan's Avatar
Thanks,
HRG
Either that or just an internet troll. I love them.
Journeyman Plumber
Old 04-08-2012, 03:11 PM   #14
Rewards Points: 990
Thanks Alan. I had ordered a different shower head from ebay prior to this thread. If it doesn't perform to our expectations, I'll try the Forte shower head that you're using.
Apologies to the OP for diluting this thread. Hope you can respond to my question about how you like your delta wide shower head.
Thanks,
HRG
Old 04-10-2012, 10:01 PM   #15
slow drain
To anyone that was following my origional thread and question. It's a miracle! My wife kept using the shower even though the shower kept backing up. After 4 showers, the shower stopped backing up and draining just fine. I have to think that some trash fell in the pipe, even though I thought that I was careful to keep it closed off during construction and tiling. Thanks to everyone who replied with input. I am a very happy guy. Mainly because my wife isn't going to kill me.
Arrrgh free!
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 09:36 PM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 11:07 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 07:28 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
