Shower Drain Plugged By A Sock - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2010, 03:26 PM   #1
Shower Drain plugged by a sock
We have a 2-story home with one of the bathrooms upstairs. One of our wonderful daughters tried using a sock to plug the bathtub and consequently the sock went down the drain. Any suggestions?
Goosebay is offline   Reply With Quote
Old 03-22-2010, 04:00 PM   #2
First thing I can think of is to buy a 25' auger and snake it into the drain and see if you can retrieve the sock that way.
http://www.lowes.com/pd_24645-319-LX...uger$y=14$x=20
HooKooDooKu is offline   Reply With Quote
Old 03-22-2010, 04:25 PM   #3
waterman1971's Avatar
Rewards Points: 154
Maybe try some thin wire and a fishhook?
waterman1971 is offline   Reply With Quote
Old 03-22-2010, 04:30 PM   #4
Unless there is a clean-out fixture in the general area, I would go with the auger. The risk is that you push if further down and make matters worse, but depending on the sock either you can try to snag it and pull it up, or if it is a thin one you can chew it up with the auger.
If you are blessed with a handy to reach cleanout, I would try the same procedure from the bottom if possible.
Hodag is offline   Reply With Quote
Old 03-22-2010, 04:55 PM   #5
the Musigician
DangerMouse's Avatar
If it's close enough to the opening, try a 2 dollar Zip-It plastic drain cleaner.
It should hook a sock as easily as it would a clog of hair.
DM
Old 03-22-2010, 07:57 PM   #6
Handyman
Rewards Points: 512
Wait about 4-5 days and check the clothes dryer..they eventually turn up
canadaclub is offline   Reply With Quote
Old 03-22-2010, 09:18 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I say push it down. Your bathtub is only 1-1/2" drain.
Being that it's an upstairs bathroom, that tub is more than likely fairly close to the toilet line - 3". Once you push it into the 3" it shouldn't be an issue.
Journeyman Plumber
Old 03-22-2010, 09:21 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
dou you know how far it went? maybe plug off the overflow and try a good shop vac if its not too far in there
plummen is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
Plugged master shower drain tam331 Plumbing 1 12-06-2006 11:33 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
