Shower Drain Pipe Compromised? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2012, 11:47 AM   #1
Shower drain pipe compromised?
Hi. While removing the old shower pan, which was attached to the PVC drain pipe with a gasket, i accidentally put some gouges in the outside of the 2" drain line. Does this compromise that section of pipe? The only access to replace it is through the shower subfloor. i will be installing a Kerdi drain.
CDale is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 08:43 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Joining ABS p-trap under shower to C.I. drain pipe warriorfox Plumbing 4 01-01-2009 02:29 AM
