-   -   Shower drain not centered for new fiberglass shower pan (http://www.diychatroom.com/f7/shower-drain-not-centered-new-fiberglass-shower-pan-87791/)
keyboarder 11-26-2010 02:35 PM
I am trying to install a shower pan over concrete in our basement and I have not 1 but Six issues. I want to do it right and have no leaking or mold issues in the future. If you guys can help me out I would sure appreciate it. I wanted to get this done this weekend but hit a lot of snags already.
Is the solution to build up something under the pan so it's level and far enough above the drain pipe that I can use an offset drain? Can I just use wood beneath it?
  1. The old drain pipe sticks up too high
  2. The old drain pipe is off center
  3. Drain pipe is smaller than the 2"ID "no caulk" drain I bought
  4. The Pan is tight between the drain edge and the studs behind the shower, so the pan doesn't wiggle anywhere.
  5. The pan isn't perfectly level.
http://lh4.ggpht.com/_-sQ6TN93LvU/TP...800/photo1.JPG
http://lh6.ggpht.com/_-sQ6TN93LvU/TP...800/photo3.JPG
http://lh5.ggpht.com/_-sQ6TN93LvU/TP...800/photo2.JPG
http://lh4.ggpht.com/_-sQ6TN93LvU/TP...800/photo4.JPG
http://lh6.ggpht.com/_-sQ6TN93LvU/TP...800/photo7.JPG
http://lh3.ggpht.com/_-sQ6TN93LvU/TP...800/photo5.JPG
http://lh6.ggpht.com/_-sQ6TN93LvU/TP...800/photo6.JPG
rjniles 11-26-2010 03:29 PM
Demo enough concrete to get down and move the drain to where you need it. I would do enough to transition to PVC and replace the trap.
keyboarder 11-26-2010 03:41 PM
Holy smokes! Thank you for the reply but is there any other way?
rjniles 11-26-2010 04:04 PM
Demoing the concrete is really not that hard. The only other way is to redo your framing to move the pan to center over the pipe. And you still will have to find a way to connect the drain to that old galvy pipe.
keyboarder 11-26-2010 04:28 PM
Removed.
keyboarder 11-26-2010 04:53 PM
UPDATE: I measured the location of the pipe and it appears it's center is 16" from the back wall, 15 3/4 from left wall and 16 from right wall. So a 32x32" would be a better fit, though it would still be off about .25" side to side.
The shower pan/kit that I bought is 32x34" and the hole is in a different place.
If I go get the 32x32" size, how will I get that drain that sticks up so high to work with it?
keyboarder 11-26-2010 06:15 PM
I went and bought a 32x32" pan and it lines up better, though not perfectly centered. Will this do?
What is the best way to make this type of drain usable with this pan? It still sticks up quite high in addition to being off center.
If I had my preference I'd like to keep the pan directly on the concrete so the front of the shower pan is flush with the ground. if I do it any differently, I'll have to put something under the front of the pan and I don't think that will look as good.
http://lh4.ggpht.com/_-sQ6TN93LvU/TP...owerDrain2.JPG
TheEplumber 11-26-2010 06:15 PM
199 Attachment(s)
I assume that your pipe is cast iron. Use cut off blade in a small grinder. Establish the height you want and carefully cut off the excess. Please use eye protection!
Install your drain assembly first so you will have an accurate measurement
immeraufdemhund 11-26-2010 06:37 PM
I agree with eplumber.
also if you want to get your tub perfect you could notch your back wall were you pan is, looks like you'd only need to make 4 cuts (two cuts about 1/4" on both the studs.) then shim it properly to make it square. Also in terms of level I would get some thin set and make that floor perfect as it will let your shower pan last longer. and if you raise it high enough you won't have to cut that drain (but I would cut the drain so you don't have to spend too much time raising the floor.
southernmom 12-01-2010 08:30 PM
I am having the same problem as you. I went to a plumbing supply shop and they gave me a rubber thing to put down the cast iron pipe so I could use the pvc for my fiberglass pan. You are a little luckier than me, I have to build onto my walls since my drain is not close to being centered. Best of luck and post pictures when you get done. Where did you get your 32x34 pan, I am looking for one
