Shower Drain -- Normal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2013, 01:58 PM   #1
I have recently discovered a leak on the opposite wall of the shower (ground floor) which is seeping up from the floor. Only gets wet after running the shower. Looking closer at my shower drain I noticed a space-- is this normal? Is there anything in this photo that looks like it could be the problem?
bsmith_tsu is offline   Reply With Quote
Old 02-03-2013, 04:04 PM   #2
Rewards Points: 14,026
I'm not seeing anything about that drain that looks right.
Where the drain strainer?
It's suppost to look something like this.
http://www.bing.com/images/search?q=...lectedIndex=23
Looks like the drains trim ring just popped through that floor then someone tryed using PVC glue to try and fix it.
Even the hole for the drain looks way over sized to me.
Old 02-03-2013, 08:51 PM   #3
I took the strainer off to make it easier to see the space. Here is another photo including the strainer.
Tags
drain , leak , shower
Shower drain problem SUPPO Plumbing 5 02-04-2012 11:04 PM
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 09:29 PM
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 07:27 AM
Basement Shower Drain bigbran Plumbing 3 02-22-2011 09:21 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
