Shower Drain Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2011, 06:42 PM   #1
Rewards Points: 350
Shower Drain Leak
Upstairs we have a shower stall. I noticed when I ran the water to test for hot water, that water started dripping at a pretty good pace in the downstairs kitchen cabinet, right above the shower....
Flushed the toilet in the upstairs bath, no dripping (thank goodness)!!
Ran the sink, no drip.
Ran the shower, lots of drip.
I took a gallon of water and poured it straight into the drain pipe of the shower (removed the screen). No drip....hmmm....something with the way the drain is attached to the shower stall body??
Any ideas on where I would start with this....I don't want to just start laying caulk around the drain everywhere where I think it could help!
dougp23 is offline   Reply With Quote
Old 10-17-2011, 09:30 PM   #2
Rewards Points: 79
possibly the shower head riser pipe in the wall is leaking. run the water as a bathtub if you have the spout and see if it leaks then. or remove the trim behind the valve handle, turn on the water, and look for leaks inside the wall from above. if it's been remodeled or if you've hung something it may have a screw going into the pipe
Dwillems is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 10:07 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
