Shower Drain Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2011, 11:53 AM   #1
Shower Drain Leak
Hi all -
I discovered yesterday that I had a water leak in my closet, and this morning traced it to a shower drain in an adjacent room.
I took the strainer off, and after cleaning the biggest, most disgusting hair ball I've seen in my life :-), see this:
There appears to be a gap between the brass (?) drain and the drain pipe. Is there something missing there? Moreover, drain doesn't appear removable, or does it?
Any suggestions on how to repair this?
Thanks!
joelq is offline   Reply With Quote
Old 04-14-2011, 11:18 AM   #2
Owner
LateralConcepts's Avatar
Hopefully it's not slab on grade. Is this shower upstairs, downstairs, main floor? Do you have a crawl space? Are you able to access the drain from under the shower? That's what you'll need to do.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Can not figure this non-traditional shower drain speedster1 Plumbing 6 10-14-2010 05:52 PM
Shower drain phymonkey Plumbing 0 10-04-2010 03:19 PM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-22-2010 12:45 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
