Shower Drain Gasket Install Tricks - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2006, 09:26 AM   #1
Shower drain gasket install tricks
I have a fiberglass molded shower base by EL Mustee. The drain is molded into the piece. There is a hole where the 2" drain pipe comes through. Then there is a gasket that fits tight around the pipe and shower base molded drain.
I have removed the old gasket and installed a new one but it was so hard to get in that a couple peices of rubber broke off. I tried lubing it with soap and it helped but not enough. Any other advice to getting this in before I ruin another gasket? I'm replacing it with the exact part from the manufacturer (p/n 32.401 from EL Mustee).
thanks for any advice.
dbrew is offline   Reply With Quote
Old 12-29-2006, 05:59 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Are you share the pipe is stright and plumb.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-29-2006, 07:25 PM   #3
I'll check to see if it is straight tomorrow but the drain pipe is not perfectly centered in the hole. I did pull it to center while installing it. It probably needed about 1/8 - 1/4 inch of movement to be center. By eyeballing it it looks straight but I can get a level on it tomorrow.
I am guessing they should be tight and maybe a little difficult to put in but I think this is harder than I expected.
Will any lube other than soap help? I tried soap and it helped but still couldn't get the top part down without tearing it.
Thanks for helping
Old 12-29-2006, 07:34 PM   #4
Journeyman Plumber
Soap is the best option, it is not easy but, persistance will prevail.
Old 12-30-2006, 07:10 PM   #5
Well, I have the gasket in place. I decided to file/sand the outer edge of the 2" drain pipe just a little bit to round the edge. It felt too sharp and thought it might be grabbing & tearing the gasket. Once smoothed down, I tried again with some soap for lube and it went on much better. It still went on hard but the gasket wasn't damaged in the process.
I placed a little silicone around each edge of the gasket to seal it. The gasket went in most of the way but not quite flush at the top. It had a little lip about 1/32 - 1/16 in. I think it was bottomed out so they may have cut the pipe just a bit short. I don't think it will be any issue as there is enough material around the pipe.
Not sure it solves my leaking issue yet but it will rule out any gasket problems.
I'll try tomorrow and see what happens when the Silicone is dry.
Thanks for helping.
Old 03-10-2010, 08:13 PM   #6
Shave edge of base to center pipe
If the pipe is not centered, stick a pocket knife between the pipe and the base and shave a small bit of the base all the way at the bottom to allow the pipe to move over and be centered. Also, chamfer the top edge of the pipe with the knife. Then put dishwashing soap and water all over pipe and gasket and using a hammer, first tap it in working around the gasket. Then use a dowel to tap the gasket all around and stop with it just above the level of the pipe.
bj139 is offline   Reply With Quote
Old 03-10-2010, 10:20 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
This is what people call 'gravedigging'
This topic is 4 years old.
Journeyman Plumber
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 07:22 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
