Shower Drain Clogged - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2008, 07:55 AM   #1
Shower drain clogged
water collects in my parents tub whenthey shower lately. My mother used drano and now its 50 times worse. The water will barely go down at all. It didnt drain after 8 hours. Is there another stronger chemical or a way for us to snake it without a plumber coming over?
flashme18 is offline   Reply With Quote
Old 05-20-2008, 05:10 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can try a hand crank snake and hope you can maneuver the tight corners.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-20-2008, 07:41 PM   #3
my dad called a plumber..thanks
Old 05-21-2008, 12:03 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I realize you've already tackled this, but for future reference :
First thing I usually do is get a long pair of tweezers and pick around in the lower shoe of the waste/overflow. If you don't get a humongous wad of hair(or several wads), the next thing is to pull the screws out of the overflow cover, and snake it that way.
Journeyman Plumber
Old 05-21-2008, 05:04 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I never use caustic drain cleaners like Drano.
This always works for me...a good non-caustic, enzyme-based drain cleaner like DrainCare.
Just run a little warm water down the drain, pour in the DrainCare, let it eat overnight, and then flush it down with very hot water the next day. I use a kettle of boiling water to start the flushing.
An enzyme-based drain cleaner won't harm your fixtures or pipes, but it WILL eat out all organic gunk (hair, soap scum, etc.). If the clog is really bad, you may have to do it more than once.
Try it next time, you won't believe how well it works.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-21-2008, 08:01 AM   #6
When is fishing season?
CowboyAndy's Avatar
We have this problem often, and it's usually caused by hair. What I usually do is start plunging, pulling up with a bit of force and it will start to pull the hair out, then i just grab ahold of it and pull it all out. Usually gets most of it out...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 05-21-2008, 09:19 AM   #7
Mike is right about the DrainCare. We were having to plunge or use a product called Thrift to clear a slow shower drain every week or two. I kept reading on here and other sites about DrainCare and decided to give it a try. I did like Mike suggested, started with hot water in the drain and let it set overnight then flushed with a pan of boiling water the next morning. It's been three months now and has not been a problem since. Amazing.
cjett is offline   Reply With Quote
Old 05-21-2008, 06:50 PM   #8
thanks for the suggestions guys..it was too late for me to intervene and stop my dad from paying for a plumber...i will try your suggestions next time we have a problem and pass the info onto anyone else having this issue in the future
Old 05-22-2008, 11:16 AM   #9
Hey guys,
We constantly have that problem at my house, so i just wanted to let you know that you're comments were also very useful to me.. THANKS! Have a nice day!
Sasha
Last edited by Ron The Plumber; 05-22-2008 at 11:41 PM. Reason: Removed Web Limks.
sasha689 is offline   Reply With Quote
Old 05-23-2008, 03:01 AM   #10
Rewards Points: 518
Just did this - 3 women in the house - removed cap, removed all hairballs with screwdriver and pliers, pour a few cups of bleach down, let sit for 10 minutes or so, flush with hot water from tap for another 10 minutes. Works everytime.
n0c7 is offline   Reply With Quote
Old 05-23-2008, 07:11 AM   #11
Mold!! Let's kill it!
Rewards Points: 2,012
I remove the chrome cover. Take my shop vac (wet rated) and suck all the hair out of the trap. It's pretty nasty, but quick and effective. No chemicals, no plunging. Open the window, cause it will smell bad. Remove the vac filter first. Run some water in all the bathroom drains to refill the traps when finished.
Old 05-23-2008, 01:29 PM   #12
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Great advice all, I think Drano was invented by a Plumber who specialized in replacing pipes. Probably the same guy who invented those chlorine tablets that eat up all the plastic parts in the toilet tanks.
I am going to try some Drain Care on my own shower. It slowly stops up about every 3 months. (My wife says I'm like the mechanic who won't fix their own car.)
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 05-23-2008, 07:50 PM   #13
My grandfather always said "The shoemaker's kids go barefoot"
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Clogged Shower Drain..Auger Bent! Too Big?? bswain06 Plumbing 2 05-12-2008 04:03 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
shower drain nomoney Plumbing 4 05-19-2006 09:27 AM
