Shower Drain Clogged? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 06:04 AM   #1
My shower drain tends to overflow when there is more water than it can drain. It still drains it, but it does it slowly... I think its weird because when I look down into the shower drain I see standing water in it and whenever I turn on my shower head the water starts to overflow, which I start to turn the shower head off. The water eventually drains to a point where the standing water stays at the same level. I have poured almost half bottle, the drain clogging agent is called "Instant Power." What should I do if the water always drains but than it stops and becomes standing water at a specific spot?
Thanks in advance
decaboy is offline   Reply With Quote
Old 04-16-2011, 06:31 AM   #2
If it is an old house, say before 1970, it may have a cast drum(bell) trap. They are nearly impossible to clean with a snake, and the cleanout cap(if accessible) is usually impossible to remove. In addition, years of use have added buildup to the wall of the galvanized drain line. If you can get a snake down it, that is your best bet for opening it up.
Old 04-16-2011, 10:00 AM   #3
Owner
LateralConcepts's Avatar
Thanks in advance
There should always be standing water in there. That's the p-trap you're looking at. It keeps sewer gases from coming back into the house. You should avoid using drain cleaners. Clear it with a power snake (3/8" cable). If you don't know how, or aren't comfortable doing that, hire a drain cleaning company. It's most likely just accumulation of hair, soap scum, etc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
plumberinlaw (04-16-2011)
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
1 1/2" shower drain tlynn Plumbing 3 02-25-2010 05:09 PM
shower pan soft around drain jpostal Plumbing 8 09-01-2008 12:18 PM
