Shower Drain Attachment Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2012, 01:56 PM   #1
Shower drain attachment questions
I'm attaching the drain to a Vigo shower base using a Kohler drain (photo). Instructions call for plumber's putty at the flange of the drain itself. Without getting into the putty vs silicone argument (if that's possible), is there any clear disadvantage or future problem if I just use clear silicone?
Secondly, this style has the gasket insert that goes between the drain frame and the drain pipe. Is this gasket the only thing supporting the pipe from the drain, such that I would have to brace the pipe in the crawlspace so it didn't slip out of the gasket?
Also, how reliable are these types of gaskets in general? Do they need any help to seal?
Thanks in advance.
David
lynxpilot is offline   Reply With Quote
Old 09-25-2012, 04:19 PM   #2
using silicone will make it really hard to get out in the future.
that would be the only disadvantage i can think of. i was a plumber for 20 years and always used putty and never had any problems unless they were defective materials. i think less than average plumbers started using silicone to make them have less leaks from improper installations. if you have ever had to remove a drain from a sink or shower that was siliconed you wouldn't ever use it.
The Following User Says Thank You to DannyT For This Useful Post:
lynxpilot (09-25-2012)
Old 09-25-2012, 04:30 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 546
I personally prefer silicone. It's just my preference tho. Seen too many failed basket strainers and I feel (no proof) that silicone holds up to high temps better.
As for the Kohler strainer, the p trap should be supported regardless of the connection method. I prefer a solvent weld connection though.
The Following User Says Thank You to TheEplumber For This Useful Post:
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Shower Drain in Concrete Slab Install sharp21 Plumbing 4 08-30-2012 10:51 AM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
Shower drain not centered for new fiberglass shower pan keyboarder Plumbing 9 12-01-2010 08:30 PM
