Shower Drain Alignment - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2012, 09:23 PM   #1
Shower drain alignment
We are replacing bathtub with shower on concrete floor. The drain in the new shower pan is not aligning with existing pvc drain. the shower pan is too close to the floor to attach a new off-set drain. What can we do?
SharonJean is offline   Reply With Quote
Old 07-24-2012, 09:27 PM   #2
Rewards Points: 616
take picture and post of what you can see without shower in place
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-24-2012, 09:28 PM   #3
Rewards Points: 616
dig out dirt remove trap and realign using new trap and other fittings as needed
Old 07-24-2012, 09:29 PM   #4
Rewards Points: 582
band bang bang went the hammer...break out alittle concrete so you can off set drain...
Old 07-24-2012, 09:40 PM   #5
concrete has been broke out. drain is too low coming out of shower pan and the existing drain has threaded coupling on it that is too high to cross it over to it.
Old 07-24-2012, 09:43 PM   #6
Rewards Points: 582
ok as jay said picture would help;;
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaydevries (07-24-2012)
Old 07-24-2012, 10:00 PM   #7
sorry I'm having trouble attaching the picture
Old 07-25-2012, 12:04 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 348
How to attach a photo to a post
Old 07-25-2012, 12:03 PM   #9
I had the same problem at first. The size of the image seems to be critical to DIY. You might try this:
In your photo browser select the image(s) then select edit. Select crop. Then there should be a drop-down menu that will let you choose a custom crop. Enter 620x280 (pixels). Choose done. Repeat for any other images. Some images may have to be rotated. Now your images should be 100,000 or less. Then proceed to the Attach File option below or the Paperclip icon above. (Note the little down arrow next to the paper clip. You'll use it in a minute)
Once you have uploaded your image to DIY place your cursor on the next line of the text box. Click the little arrow. Select the image and it should appear as [Attach]Img.#[.....]. When you preview your post the image will appear at that cursor location in the body of the text. Hope this helps.
crashdavid is offline   Reply With Quote
The Following User Says Thank You to crashdavid For This Useful Post:
ben's plumbing (07-25-2012)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 09:36 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
