Old 01-19-2007, 04:27 PM   #1
Shower Drain
I was wondering which solution would be best for my situations.
I am installing an acrylic corner shower (base and walls) from Maxx. The bathroom is on the second floor above my family room.
Should I use a solvent weld shower drain or a no-caulk shower drain, and why?
Mark
Blaze25 is offline   Reply With Quote
Old 01-19-2007, 05:25 PM   #2
jproffer's Avatar
Shower Drain
I would say the purpose of a "no caulk" (assuming you mean a compression type trap ass'y, such as is likely under your kitchen sink) is to be able to remove and clean any blockage. If the shower in question is on a second floor, that's not going to be an option no matter which type you choose, and I personally feel a glued joint is better than a compression joint.
Which is why I would go with a glued set-up
jproffer is offline   Reply With Quote
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
noisy shower drain pump zoodemon Plumbing 5 10-04-2006 01:22 PM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
