Old 05-17-2006, 01:50 PM   #1
shower drain
hello,
when the slab was poured there was no planning for the shower drain( the bottom portion ).
i am slowly chewing my way down through the slab to install the drain so that it is flush with the floor....so i can install the shower membrane.
i am getting periously close to the earth under the slab( approximately 6 inches deep ).
my plan is this, if i break thru to fit the drain.....i will push in morter around the sides of the 'crater' under the drain lip after i glue the drain in....and declare victory
am i dreaming??
nomoney is offline   Reply With Quote
Old 05-18-2006, 12:46 AM   #2
renovations
shower drain
Where's the drain going to drain to? Are you installing a 2" pipe and p-trap under the concrete?
Bonus is offline   Reply With Quote
Old 05-18-2006, 02:45 PM   #3
shower drain
yes sir, there is a 2" pipe and further down is a p-trap so i am OK there.
I finished last night and instead of using mortar, i used sakrete. the drain( bottom portion where the membrane connects to is perfectly level with the concrete floor of the to-be shower.
Old 05-18-2006, 05:36 PM   #4
shower drain
If using a 2 part clamping drain and a cpe or pvc liner, you need the floor sloped to the bottom part of the drain, it's called a pre-slope, this is for any moisture that get's through the tile and mortar to the liner and runs down to the weepholes.
R&D Tile is offline   Reply With Quote
Old 05-19-2006, 10:27 AM   #5
shower drain
thankyou all for the info.
the work goes on..........
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Shower Drain Blaze25 Plumbing 1 01-19-2007 05:25 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
noisy shower drain pump zoodemon Plumbing 5 10-04-2006 01:22 PM
