-   -   shower drain (http://www.diychatroom.com/f7/shower-drain-2522/)
nomoney 05-17-2006 12:50 PM
shower drain
hello,
when the slab was poured there was no planning for the shower drain( the bottom portion ).
i am slowly chewing my way down through the slab to install the drain so that it is flush with the floor....so i can install the shower membrane.
i am getting periously close to the earth under the slab( approximately 6 inches deep ).
my plan is this, if i break thru to fit the drain.....i will push in morter around the sides of the 'crater' under the drain lip after i glue the drain in....and declare victory
am i dreaming??
Bonus 05-17-2006 11:46 PM
Where's the drain going to drain to? Are you installing a 2" pipe and p-trap under the concrete?
nomoney 05-18-2006 01:45 PM
yes sir, there is a 2" pipe and further down is a p-trap so i am OK there.
I finished last night and instead of using mortar, i used sakrete. the drain( bottom portion where the membrane connects to is perfectly level with the concrete floor of the to-be shower.
R&D Tile 05-18-2006 04:36 PM
If using a 2 part clamping drain and a cpe or pvc liner, you need the floor sloped to the bottom part of the drain, it's called a pre-slope, this is for any moisture that get's through the tile and mortar to the liner and runs down to the weepholes.:)
nomoney 05-19-2006 09:27 AM
thankyou all for the info.
the work goes on..........
