Old 03-07-2008, 11:01 AM   #1
Shower Drain
In my shower with tile floor, sealing around the drain opening went off. Could anybody tell me please what I should use to replace it?
Thanks in advance.
dpreznik is offline   Reply With Quote
Old 03-07-2008, 02:00 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Shower Drain
Post a picture.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-07-2008, 03:14 PM   #3
Shower Drain
Do you know what the original sealing material was? If it was Plumbers putty, I would say you have something loosening up for it to escape. Silicone wouldn't go anywhere. Please take the time to find the cause before you attempt repairs. Check to see if the drain flange can be wiggled.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-09-2008, 11:25 AM   #4
Shower Drain
I don't know the material of the seal. I will attach the picture soon.
Old 03-09-2008, 11:30 AM   #5
Journeyman Plumber
Shower Drain
No picture shown
Old 03-09-2008, 06:42 PM   #6
Shower Drain
Originally Posted by Ron The Plumber View Post
No picture shown
Here it is.
Old 03-09-2008, 06:45 PM   #7
Journeyman Plumber
Shower Drain
Thats silicone, not needed if the screws seen across from each other, hold the plate done in place.
Old 03-09-2008, 10:28 PM   #8
remodeling pro
Shower Drain
Like Ron said, that giant smear of silicone is not needed. The metal grate is purely decorative and does not need to be sealed. The waterproofing should have taken place between the pan liner and the clamping flange, now buried under the tile and mortar bed.
troubleseeker is offline   Reply With Quote
Old 03-10-2008, 09:06 AM   #9
Shower Drain
Thank you so much for the peace of mind you gave to me.
Different type of shower drain? canadaclub Plumbing 8 03-04-2011 10:08 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
shower drain nomoney Plumbing 4 05-19-2006 10:27 AM
