Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2012, 10:49 PM   #1
Shower drain
Hi, in my shower water leaves well, but when I opened strainer I see water in the pipe about two inches below the shower floor, but when I run water it doesn't accumulate , leaves ok. Is it normal to always have water in the pipe? I checked it only because after I am on trip, shower not used for a week, some stale water smell, probably because of water always in the pipe. I tried drano or pump, no change. Thanks
Zopato01 is offline   Reply With Quote
Old 04-15-2012, 10:58 PM   #2
The water that sits in the shower drain is there for a reason. It sits inside what is known as a P trap and maintains a water seal so that the sewer gases from your drainage system do not travel into your house.
Perfectly normal and infinitely preferable.
VIPlumber is offline   Reply With Quote
Old 04-16-2012, 09:34 AM   #3
Thumbs up
Thank you so much!
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Drain pipe size for roll in shower frickell Plumbing 1 04-05-2012 08:36 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
