Shower Door Seal - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2012, 08:58 PM   #1
Rewards Points: 398
Shower door seal
Not sure if this is the right area, so let me know of I should post in another section.
I was cleaning my shower doors when the one slipped on the floor and fell on the ground. When it landed it appeared the one side was loose. I looked closer and saw the glass seal tucked inside on both sides. I tried to run a flat blade screw driver along the edge to tuck it out but it wouldnt budge.
Is this fixable? I see the one edge has an end but I don't want to undo it and make it worse.
adgjqetuo is offline   Reply With Quote
Old 07-24-2012, 09:02 PM   #2
DIY staff
Rewards Points: 7,174
You may need to take that frame apart and reset that gasket--If it's shot---contact the door company or call a local glass shop and get a new gasket--
For that gasket to have shifted like that--something got knocked loose or bent--so check all screws---
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
