Shower Diverter Questions... - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2010, 06:01 PM   #1
Rewards Points: 31
Question
Shower Diverter questions...
Hi all -
I have a 20+ year old diverter in my shower/tub. There is a small drip coming from the tub spout, and if you turn/push the shower handle in at the right spot, the drip will stop; so I'm assuming I must have some sort of broken washer/part in the diverter.
Question 1: From the pics you can see I exposed the unit, removed the retaining clip and tried to pull out the assembly but couldn't budge it. Does anyone know if this diverter cannot be rebuilt (as in, not a "removable assembly")? Do I need to replace the entire diverter...if so, eek!
Question 2: If I do need to replace the diverter, there isn't enough room to work in there. The other side of the wall is the corner of the kitchen and cabinets, so I can't come in from behind. The shower walls are a 1-piece assembly, and chances are it won't come out easily and would have to replace the tub walls (could be a nice tile upgrade! ). Suggestions?
Sorry for the long post, thanks for any help!!
Dan
Shower Diverter questions...-p1000117.jpg   Shower Diverter questions...-p1000118a.jpg   Shower Diverter questions...-p1000119.jpg
dgates12 is offline   Reply With Quote
Old 07-29-2010, 07:00 PM   #2
Owner
LateralConcepts's Avatar
You need a cartridge puller. Lots of models.. cheap and not so cheap, but looks something like this.
Pull the set pin you showed in your picture (don't drop it behind the wall), then screw the cartridge puller into the cartridge, brace yourself, and pull. If you're worried about dropping it, take a long piece of dental floss and tie it through the little hole on top and hang onto it while you pull it out with some needle nose pliers.
Replace it with a new cartridge (appears to be Moen1225b)
Replace the set pin.
Put everything back together.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
dgates12 (07-30-2010)
Old 07-29-2010, 07:10 PM   #3
DIY staff
Rewards Points: 7,174
Great directions---I'll add one simple step--roll up a sheet of fine sand paper and clean up the inside of the valve body--
That unit has it's own shut offs--however ,after twenty years I'd be afraid to use them.(shut offs are the little screws on the left and right.
Old 07-29-2010, 07:15 PM   #4
Owner
Also a good suggestion. That being said, make sure the main water is shut off before pulling the cartridge.
Sometimes they can be stubborn and kinda seized in place. Can take a lot of pressure (hence my directions to brace yourself) If it still doesn't come out, a "little" heat from a torch on the valve body won't hurt.
Lateral
(208) 818-8241
Switch shower diverter from fixture to spout? iruser Plumbing 0 06-21-2010 10:52 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
shower pan questions toolbelt Tina Plumbing 15 05-25-2009 11:56 PM
Basic Tub to Custom Shower Plumbing Questions brian3b Plumbing 13 02-19-2009 06:22 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
