Shower Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2011, 10:17 AM   #1
Darylh's Avatar
Shower diverter
I have 2 walk in showers to do and I want to put the diverter on one end and the shower head on the other. 1/2" pex. Is there any water pressure issues doing it this way? 1 shower is 32x 40 long and the other is 32x60 long
Darylh is offline   Reply With Quote
Old 02-18-2011, 12:19 PM   #2
I do not understand, Do you mean "shower valve" instead of "diverter"??
broox is offline   Reply With Quote
Old 02-18-2011, 01:15 PM   #3
rditz's Avatar
i am a big fan of the rainfall type of shower head and plan to put one directly in the ceiling when I do my remodel... not sure why, if you were still going to have the shower head on the wall, that you wouldn't put the valve on the same wall... seems like extra pipe for no reason.
rod
rditz is offline   Reply With Quote
Old 02-18-2011, 07:14 PM   #4
Darylh's Avatar
There's going to be 3 feet of glass at the shower head end and a 2 foot opening at the other end. Rather than having to walk into the shower and turn it on I could turn it on and wait for the temperature to be right instead of getting blasted with cold water. I want to put it as I described above. The issue is, the water pressure. I"ve been around this stuff a long time but I wanted to check with the pro's if this is feasible.
Old 02-18-2011, 07:48 PM   #5
It is feasible, just don't run that overhead line in an unconditioned space, or it could freeze and bust.
Old 02-18-2011, 09:38 PM   #6
Darylh's Avatar
waterline is going down and under the 2nd floor
Old 02-18-2011, 09:44 PM   #7
Rewards Points: 212
it will be fine to do that way put as few elbows as possible, or run pex
bluebird5 is offline   Reply With Quote
Shower diverter valve prob ProAmateur Plumbing 1 12-27-2010 09:28 AM
Shower Diverter questions... dgates12 Plumbing 3 07-29-2010 07:15 PM
Switch shower diverter from fixture to spout? iruser Plumbing 0 06-21-2010 10:52 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
