Shower Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2009, 09:25 PM   #1
shower diverter
i have replaced the diverter twice, still leaks, can i replace the main line running to the shower, or cut out that section and replace with flex tubing. when i turn the diverter knob a lot of water still runs out the faucet
johnreinier is offline   Reply With Quote
Old 06-17-2009, 06:35 AM   #2
I assume this is a 3 handle faucet with center handle being the diverter?? You say you replaced it, what did you replace?? It works just like the other two valves, with a hard rubber washer, and brass seat. If you replace the valvestem or washer, the problem could be a bad seat, usually replacable(if you can get it out, need seat wrench).
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Shower Diverter Valve replacement twildey Plumbing 10 12-18-2008 09:43 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 09:54 PM
