Shower In Different Room Runs When Tub Runs. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2013, 02:56 PM   #1
Shower in different room runs when tub runs.
Have a tub only (no shower) in one room, and a shower only (no tub) in a second room. Suddenly when the tub is turned on, the shower runs fairly strongly in the other room. Any suggestions as to what could be causing this?
xinodahsnosaj is offline   Reply With Quote
Old 02-16-2013, 05:09 PM   #2
Roofmaster
Rewards Points: 2,172
This is a rib right?
Old 02-16-2013, 08:17 PM   #3
I have seen things like this before. It was something in one of the valves. Ah??? I think it was a bad cartridge in a Moen faucet somehow pulled the kitchen sink on. Long time ago. No ghosts here
paintdrying is offline   Reply With Quote
Old 02-16-2013, 08:45 PM   #4
Rewards Points: 1,492
Did it ever work correctly?
Was the shower head connected to the wrong faucet assembly, namely for the other room?
Old 02-16-2013, 09:08 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 540
Once I installed a new T&S Brass 2 handle faucet- it would turn itself on. I tightened the packing nut a little and problem solved
Old 02-16-2013, 09:25 PM   #6
Rewards Points: 582
defective pressure balance cartridge ...when tub is turned on drops pressure in shower causing unbalance ????? replace shower cartridge and try it again...ben sr
Old 02-17-2013, 07:02 PM   #7
Thanks for the replies. No, it's not a rib. I was up visiting family and their bathtub/shower is actually doing this. Their tub faucet is a compression style faucet where both handles and the spout are all one unit. I didn't pull it apart, but I assume it just has two supply lines coming up from the basement below.
The shower is a simple two handle shower faucet that feels like it's a cartridge faucet.
Both have been in the house since they bought it a few years ago, and it just suddenly started happening. One thing I did notice after further looking at it that may or may not be relevant is the shower faucets turn backwards from what I would expect. (Clockwise turns them on, counter clockwise turns them off).
Sounds like folks are telling me to suspect something funky with the shower, and not the tub. Does just simply replacing the cartridges in the shower seem like a reasonable first step?
Old 02-17-2013, 08:50 PM   #8
Rewards Points: 582
sounds like the faucet was installed upside down..when tub is being used handle falls down in shower????? does the handle turn real easy?? ben sr
Old 02-17-2013, 10:37 PM   #9
Rewards Points: 944
There was a guy last week who could only get his toilet reservoir to fill when the shower was running.
I guess you guys are in the same subdivision?
cleveman is offline   Reply With Quote
Renovating shower room in an old house tybomb Plumbing 19 11-27-2012 07:16 AM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
