Old 02-09-2011, 11:42 PM   #1
shower curb height
ok
I have a roughly 4 by 6 foot shower subfloor with the shower drain off centered to the left 12 inches away from the wall. The shower glass door is going to be located to the right due to the fact the toilet is next to the shower.
how high do i build the shower curb? Do I stack 2 2x4s or only use 2 2x4s
let me know!
chulett is offline   Reply With Quote
Old 02-10-2011, 07:27 AM   #2
Super Moderator
shower curb height
I suggest 3 --2x4s---You have 5 foot of pitch--1 1/4 inches plus the drain height and mud bed--
That sound about right---
Good reading here--Shower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
Old 02-10-2011, 10:11 AM   #3
Moderator
Termite's Avatar
shower curb height
A agree with what has been said about the height.
However I personally would never consider doing it with wood. I'd form it up and dry pack the curb with the same mud that you use to make the shower base.
Old 02-10-2011, 10:27 AM   #4
Super Moderator
shower curb height
KC--how is that done? I build the curb with wood---it is then covered with the liner ---
then expanded mesh--then 'fat mud' a wetter mud than the pan gets----I always like to know more than one way to skin the cat----Mike---
Old 02-10-2011, 11:59 AM   #5
Experienced
Jackofall1's Avatar
shower curb height
Chulett, if you buy the preslope complete kit from http://www.markeindustries.com/kirb-perfect.html it will have a curb form with the kit, works real well.
The liner does go over the wood so I would not worry about that, Ohmike is correct, if you are getting water past the liner, there is a far worse problem to worry about.
Mark
Old 12-10-2011, 11:47 AM   #6
shower curb height
I built up a shower pan curb with three 2x4s. Once I put the mud on, i'm left with 2" from the shower pan to the top of the curb (which does have a slope toward the inside). Is that enough of a rise for the curb or do i need to go back and add more mud before i start tiling? If so, can i just build up more mud on top or do i need to put some type of primer or do some scoring in the curb to get the new mud to stick? Thanks.
autx790 is offline   Reply With Quote
Old 12-10-2011, 11:57 AM   #7
Tileguy
Bud Cline's Avatar
shower curb height
autx790
Why don't you start your own thread and not hijack this one ?
Old 12-10-2011, 01:42 PM   #8
shower curb height
Well since this thread died in February, and it had the same subject as what i was going to start. I figured i'd add on to this one. Also if some else was going to search later on for the same thing, they could get the same info from one thread instead of two. Wasn't trying to be obnoxious.
Old 12-10-2011, 02:18 PM   #9
Tileguy
Bud Cline's Avatar
shower curb height
Okay have it your way. According to your post count you are no stranger here and you must have (by now) realized that hijacking threads is discouraged but in this case you may be correct.
Shower curb Joe F Tiling, ceramics, marble 0 08-09-2010 09:36 AM
Damaged Shower Curb ohiogirl1965 Plumbing 0 06-29-2010 03:56 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Custom Shower Curb nelsonc2121 Tiling, ceramics, marble 23 02-10-2010 05:43 PM
shower curb toolbelt Tina Tiling, ceramics, marble 7 07-11-2009 08:30 PM
