Shower Controls Loose - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2009, 11:17 AM   #1
Shower controls loose
The hot and cold knobs and the faucet have some play in my shower. If you move one back and forth all 3 move which makes me believe that the pipes have come loose from the studs inside the wall. There is no access panel. My question is how can I tighten them without removing the tiles? Would it be best to cut a hole in the drywall from the other side of the wall? If so how will I be able to secure the pipes working from behind? I don't think I would be able to get a drill or screwdriver in that space.
gamble is offline   Reply With Quote
Old 02-13-2009, 11:27 AM   #2
Cut an access in the wall behind the shower valve. Install blocking and use strapping to tighten the valve against the blocking.
jerryh3 is offline   Reply With Quote
Shower controls ctsmiths Plumbing 7 02-16-2009 04:12 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
