Shower Control - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2010, 02:08 PM   #1
Shower Control
Hi all,
we have two bathrooms and both baths have ONE knob for the water control. how difficult is it to convert a one knob water control to a standard 2 knob control?
reds_21 is offline   Reply With Quote
Old 09-20-2010, 02:54 PM   #2
DIY staff
Rewards Points: 7,174
From a plumbing stand point the change out is quite straight forward---cut the old mixer out--
sweat in a new one---
The biggest trouble I see is that the wall must be opened up--A hole about 14x 10 minimum--
If you are redoing the baths--easy-----not reworking the baths--forget it.--Mike--
Old 09-20-2010, 03:03 PM   #3
not reworking the baths - forget it.
enough said
thank you
The Following User Says Thank You to reds_21 For This Useful Post:
oh'mike (09-20-2010)
Old 09-20-2010, 03:08 PM   #4
the Musigician
DangerMouse's Avatar
However...... if it's pex or cpvc, and you have easy access to it from behind, it's a relatively simple swap!
DM
Old 09-20-2010, 04:58 PM   #5
Mike summed it up, but I'll add that most double handle valves are not pressure balancing and won't pass inspection. may not matter to you until someone flushes a toilet and you turn red
the_man is offline   Reply With Quote
Old 09-20-2010, 05:06 PM   #6
Rewards Points: 286
Plus you would have to cut new holes in your finished walls for the two handles and cover the old single hole.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Speakman Kent Shower control rickheel Plumbing 0 01-01-2010 10:19 AM
2 faucet shower control - Hot H20 leaking John24689 Plumbing 5 10-28-2009 04:44 PM
Thermostatic control for shower Alanb49 Plumbing 3 02-25-2009 07:50 AM
retrofiting shower control fraz1924 Plumbing 12 09-08-2008 03:43 PM
