Old 05-22-2008, 12:59 PM   #1
Question
Shower body jets
I am installing a 5 pc body shower (1 showerhead & 4 body jets) but there seems to be no instruction on the heights for the body jets.
The showerhead will be set at a height of 6' 6" from the shower floor.
I dont want to place the body jets too high for short guests or possible sale in the future, but on the other hand i dont want to set them too low.
Any input would be appreciated on the subject.
Thanks.
Moparman is offline   Reply With Quote
Old 05-22-2008, 02:10 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Shower body jets
You have to make that decision, what is best for you, don't worry about if you sell afterwards.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 05-23-2008, 12:43 AM   #3
Doing it myself
Alan's Avatar
Shower body jets
I like to put one in the shower floor right next to the drain, so that you can have a bidet-esque cleansing if needed.
Just kidding. Full agreement with Ron. I've only helped install body jets once, and it was on finish stage, they were approximately 4 feet high, if that helps.
Journeyman Plumber
Old 05-23-2008, 11:04 AM   #4
Moderator
Termite's Avatar
Shower body jets
I rarely inspect a shower that doesn't have them anymore. I see them at all heights...Some as low as the knees, some as high as the shoulders. Put them where you want them!
Old 05-23-2008, 01:53 PM   #5
Licensed Master Plumber
mstplumber's Avatar
Shower body jets
Moparman,
I don't know what brand faucets you are using, but Moen has a pretty good installation guide at:
http://www.moen.com/literature/pdfs/MF2861.pdf
The illustrations are very clear and easy to understand.
Basically, they recommend installing the bottom set of spray heads at 39" high, the top set at 54" and making them 16" apart.
Also, make sure you install the body sprays on a pressure balance loop so they all have equal pressure. This is illustrated very clearly in the Moen literature. It is as simple as it looks in their pictures.
Good luck on the installation.
Mstplumber
Check out my goofy video for my new
mstplumber is offline   Reply With Quote
Old 05-23-2008, 08:49 PM   #6
Shower body jets
Thanks for the input guys, that guide seems like it will be very helpful when i install them
body jets help TEEBOW Plumbing 1 04-04-2008 10:37 PM
PEX for Shower Body? Tool Junkie Plumbing 5 09-27-2007 06:35 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
Shower body helpless handyman Plumbing 4 11-18-2006 10:49 PM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 09:51 AM
