Shower And Bath Fixture Replacement Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2011, 01:37 PM   #1
shower and bath fixture replacement advice
shower and bath fixture replacement help
I'm remodeling our bath and will be completely replacing the fixtures in the shower stall and roman tub. The current fixtures were installed by the builder back in 1991 (Delta fixtures). I currently have all plumbing in the shower wall and the side of the roman tub exposed as all the tile will be replaced as well so there's good access to the plumbing. i.e. -All the drywall has been removed
My question is: I'll be using Delta replacement fixtures. Will the old valves have to de-soldered off? Or will the new fixtures work on the old valves?
Just trying to determine if it would be worth my while to do the plumbing work myself or hire a pro...I've done some soldering work before with good success..but the plumbing under the roman tub looks fairly complex.
Any ball park guess how much a pro plumber might charge?
Thanks.
billyg is offline   Reply With Quote
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 05:31 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 07:54 PM
advice on shower system djrussell Plumbing 3 07-13-2009 10:39 AM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 09:38 PM
