Shower In Basement Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2008, 01:37 PM   #1
shower in basement slab
I am istalling a shower in my basement, I have a shower drain opening, a 12 x 14 opening in the slab, a black plastic box was fitted into this opening before the pour, the box is full of gravel. My question is, Do I remove the box and pour in concrete to fill in the gap or cover it with a piece of concrete board and pour my shower pan on top of it?
philip96 is offline   Reply With Quote
Old 06-14-2008, 05:27 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes after you set the trap and drain to the rough floor. After that pour the area with concrete, when all set.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-15-2008, 09:46 PM   #3
Registered User
Termite's Avatar
I'd recommend only capping the trap hole with a fairly thin layer of concrete...Only an inch or two. Fill the hole with gravel around the trap. That way you're not encapsulating the trap in concrete. If there's ever a reason for you or a future owner to need to get in there to service or replace the trap, you don't have to destroy it to get it out.
(you still might have to destroy the shower though )
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
is a pre-slope required for slab shower memjeff Plumbing 2 01-16-2009 06:57 PM
Basement shower drain help.. helpless handyman Plumbing 79 02-26-2008 09:39 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
