Old 11-27-2009, 06:08 PM   #1
Shower Base
We are trying to install a new shower base (prefab fiberglass) and it has a styrofoam unit attached to the underside of the base - is it supposed to be installed with the styrofoam in place or removed? - it's loosely glued on to the base.
smithjnj is offline   Reply With Quote
Old 11-28-2009, 06:52 AM   #2
Shower Base
If it is glued on, I would say it stays. Contact the manufacturer, or get the directions out of the trash can. They should also tell you if it needs a mortar bed.
Old 11-28-2009, 07:53 AM   #3
Shower Base
I would say it stays, for support.
My shower had nothing under it and it was flexible , to flexible meaning going to crack.
I filled the void with expanding foam now it's solid as a rock.
SULTINI is offline   Reply With Quote
Old 11-28-2009, 10:06 AM   #4
Kekeever
Kyle Keever's Avatar
Shower Base
Go to the manufacturers website. I'm sure you'll find the info there.
Kyle Keever is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Installing a new shower base frgwtchr Plumbing 2 08-17-2009 07:30 AM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 09:36 PM
