Shower Arm Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2012, 11:08 AM   #1
Shower arm help
So the shower head came off from the shower arm and it revealed a ball at the end. After reading several forums and videos on YouTube, it sounded and looked simple enough for me (it wasnít) and I had all tools as well. So I decided to change the shower arm. It took me a long time to get the shower arm out and for a second I thought it was rotating free. This is with using the channel lock and vice grips later. It finally came off.
I have attached pictures to show how the shower arm end is and the pipe opening coming through the wall.http://pix.kg/p/471090913507%3A461862819/scl
What I cannot figure out is following.
-Have I broken something inadvertently. If yes, what do I need to do to set it right?
-What things do I need to keep in mind when I am trying to install the new shower arm and head
Any insight will be appreciated
Sincerely
vcclt
vcclt is offline   Reply With Quote
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
