Shower Arm Broke Off In Pipe. Any Suggestions To Remove? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2010, 06:49 PM   #1
Shower arm broke off in pipe. Any suggestions to remove?
I was replacing my shower today, and when I went to remove the shower arm, it broke off and left the threaded end still in the pipe. Any suggestions on how to get the old piece out? I really don't want to have to replace the whole pipe, which would require removing the tiles, wall, etc. And FYI...I didn't really put too much effort into getting this out. It broke off quite easily.
mav1c is offline   Reply With Quote
Old 08-08-2010, 07:10 PM   #2
Rewards Points: 6,652
What is on the other side of the shower? You may be able to access from that side, and then replace the fitting that way.
Old 08-08-2010, 07:44 PM   #3
Owner
LateralConcepts's Avatar
Use a Sawzall or a Dremel to cut through the shower arm thread. Careful not to cut the threads on the riser, then pry it out with a chisel or flat screwdriver.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-08-2010, 08:13 PM   #4
They make a tool which is like an inside pipe wrench. Ask at your local hardware store tell them your problem they should be able to suggest the proper tool.
merle is offline   Reply With Quote
Old 08-08-2010, 09:11 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 676
Go to a good hardware store and ask for a 1/2 nipple extractor. Or you can take a flat tapered file that fits snugly inside the broken nipple, tap it with a hammer until embeds into the pipe wall. Now grip the file with a cresent wrench and unscrew the broken nipple.
Old 08-09-2010, 05:26 AM   #6
Rewards Points: 352
Once you get a internal pipe wrench/nipple extractor/file try to tighten it just enough to break the threads free. Then remove, Use rust buster
plumberinlaw is offline   Reply With Quote
Old 08-09-2010, 07:01 AM   #7
Thanks for the suggestions. My worry is that it's so corroded that even the thread removal tool won't work. I guess in that case i'll just have to try filing/hacksawing until I can get enough out to re-tap the threads.
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
thread broke off inside pipe... 68MHJCs Plumbing 5 11-04-2009 11:59 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-24-2008 11:47 PM
Unable to remove Shower valve abacuslearns Plumbing 8 10-27-2007 10:10 AM
