Should Old Plumbing Be Replaced? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2008, 11:49 PM   #1
3nr
Should old plumbing be replaced?
My house was built in 1953 and I've lived in it since 1980. I now want to use it as a rental. The electric has not been upgraded, so it will definitly need work, but what about the plumbing? The water line into the house was repaired around 1985 and the sewer line was completely reworked three years ago.
Other than replacing the bathroom sink and upgrading faucets in the kitchen, my inclination is to let sleeping dogs lie.
Thoughts?
3nr is offline   Reply With Quote
Old 05-30-2008, 11:56 PM   #2
Registered User
Termite's Avatar
If everything is in good shape, I don't see much of a reason to change. You can always replace portions of the plumbing system if and when the need arises.
Old 05-31-2008, 02:33 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Agreed, unless all of your plumbing walls are currently completely gutted, then this is the easiest time to replace water lines.
Journeyman Plumber
Old 06-01-2008, 01:22 PM   #4
3nr
Thanks to both of you for responding.
If the electric upgrade involves tearing into walls, I'll take a look at the exposed plumbing. Otherwise, I'll just wait.
Old 06-01-2008, 10:40 PM   #5
Rewards Points: 1,088
I'd do a water test to see if the lead solder used to join your pipes are leaching into the supply.
handy man88 is offline   Reply With Quote
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 08:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 12:38 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
