Should I Use A Compund Mitre Saw For Cutting 3" ABS Plastic - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2009, 08:58 AM   #1
K.M.G's Avatar
Rewards Points: 113
Should I use a Compund Mitre Saw for Cutting 3" ABS Plastic
Hi
I have put the toilet down just for temp and had one hard time cutting the 3" ABS Plastic Pipe.
Tried a Reciprocating saw(Can't hold the pipe and cut) I don't have a vise
Then used a Hack Saw,well the cut is not straight but nothing leaks (just a temp job)
I was told I should just use my 12" Compound Mitre Saw,but I don't know if the plastic will melt to the Teeth of the blade.
It did on the Reciprocating saw and smelled awful
I spent a good $400 on the saw and don't want to mess it up with a $5 Pipe.
Just seeing what you guys use to cut ABS plastic
K.M.G is offline   Reply With Quote
Old 10-04-2009, 09:20 AM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
We use PVC here, but I cut that with a reciprocating saw (sawzall) or a chop saw. Sometimes holding the pipe tightly is a bit of a PIA, but IMO its still the easiest way. You could see if you could find an abrasive blade for your miter saw (I'm sure you can) and use that. It will cut that ABS nicely.
JDC is offline   Reply With Quote
Old 10-04-2009, 09:26 AM   #3
I have used a miter saw in the past and it will work. It should cut fast enough to avoid melting. The two problems are, the chips flying off the blade are sharp, so wear face and eye protection. Other problem is holding the pipe tightly against the fence. If it gets loose, it could fly across the room or into you.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-04-2009, 05:52 PM   #4
Knucklez's Avatar
Rewards Points: 932
i bought an expensive compound miter saw, Bosch. really love the thing..
i used it for cutting ABS all the time. all sorts of sizes, no problem whatsoever.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 10-05-2009, 10:00 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
I use a power miter saw to cut plastic pipe a lot. Use a fine toothed carbide tipped blade. One with a negative rake angle is best. I never use the same blade for cutting wood. An abrasive blade is NOT the thing to use. The plastic will melt into the blade surface and become a mess. Cut all of your stubby pieces off of long lengths first. You don't want to be trying to cut short pieces with your fingers that close to the blade.
Old 10-05-2009, 10:28 AM   #6
i have a craftsman miter box that's really similar to this one. maybe the same OEM....
http://www.sears.com/shc/s/p_10153_1...word=miter+box
it works fine for 3" pipe. maybe more but that's the biggest i've tried so far. i imagine any $15 miter box will work well.
djrussell is offline   Reply With Quote
Old 10-05-2009, 08:42 PM   #7
Knucklez's Avatar
Rewards Points: 932
i used the default 60 tooth blade that came with the saw. i also use it for wood. never noticed any problems. i guess, some melting of the plastic, but that didn't bother anything that i can see. just de-burred the rim of the pipe when i was done (using a complicated finger wipe down technique) and bob's your uncle.
Knucklez
Old 10-11-2009, 09:07 PM   #8
K.M.G's Avatar
Rewards Points: 113
Thank you for the replies I have a few options i can try now
Kobalt Compund Mitre 912jake Tools 5 08-25-2009 02:48 PM
