-   -   Should I use a Compund Mitre Saw for Cutting 3" ABS Plastic (http://www.diychatroom.com/f7/should-i-use-compund-mitre-saw-cutting-3-abs-plastic-54396/)
K.M.G 10-04-2009 09:58 AM
Hi:)
I have put the toilet down just for temp and had one hard time cutting the 3" ABS Plastic Pipe.
Tried a Reciprocating saw(Can't hold the pipe and cut) I don't have a vise
Then used a Hack Saw,well the cut is not straight:no: but nothing leaks (just a temp job)
I was told I should just use my 12" Compound Mitre Saw,but I don't know if the plastic will melt to the Teeth of the blade.
It did on the Reciprocating saw and smelled awful
I spent a good $400 on the saw and don't want to mess it up with a $5 Pipe.
Just seeing what you guys use to cut ABS plastic
JDC 10-04-2009 10:20 AM
We use PVC here, but I cut that with a reciprocating saw (sawzall) or a chop saw. Sometimes holding the pipe tightly is a bit of a PIA, but IMO its still the easiest way. You could see if you could find an abrasive blade for your miter saw (I'm sure you can) and use that. It will cut that ABS nicely.
majakdragon 10-04-2009 10:26 AM
I have used a miter saw in the past and it will work. It should cut fast enough to avoid melting. The two problems are, the chips flying off the blade are sharp, so wear face and eye protection. Other problem is holding the pipe tightly against the fence. If it gets loose, it could fly across the room or into you.
Knucklez 10-04-2009 06:52 PM
4 Attachment(s)
i bought an expensive compound miter saw, Bosch. really love the thing..
i used it for cutting ABS all the time. all sorts of sizes, no problem whatsoever.
Knucklez
Maintenance 6 10-05-2009 11:00 AM
I use a power miter saw to cut plastic pipe a lot. Use a fine toothed carbide tipped blade. One with a negative rake angle is best. I never use the same blade for cutting wood. An abrasive blade is NOT the thing to use. The plastic will melt into the blade surface and become a mess. Cut all of your stubby pieces off of long lengths first. You don't want to be trying to cut short pieces with your fingers that close to the blade.
djrussell 10-05-2009 11:28 AM
i have a craftsman miter box that's really similar to this one. maybe the same OEM....
http://www.sears.com/shc/s/p_10153_1...word=miter+box
it works fine for 3" pipe. maybe more but that's the biggest i've tried so far. i imagine any $15 miter box will work well.
Knucklez 10-05-2009 09:42 PM
4 Attachment(s)
i used the default 60 tooth blade that came with the saw. i also use it for wood. never noticed any problems. i guess, some melting of the plastic, but that didn't bother anything that i can see. just de-burred the rim of the pipe when i was done (using a complicated finger wipe down technique) and bob's your uncle.
Knucklez
K.M.G 10-11-2009 10:07 PM
Thank you for the replies I have a few options i can try now
