Should I Use 3/4" Or 1/2" Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2010, 04:45 PM   #1
Should I use 3/4" or 1/2" valve
Hi all
I am new to site and would like to say thats in advance to all that help/comment on any of my issues
Let me jump right in. I am redoing my bathroom. I gutted it rigth to the beams the easy part is over. I probably should have did a little more research to see what i was getting myself into but anyway here i am.
I decide to do A shower tower either a Grohe or hansgrohe. My question is.
I have a 1/2" water feed can I use a 3/4" valve or should I stick to units with 1/2" valves. My water pressure is around 80psi.
I am looking at the
Grohe - Aquatower 3000
http://www.groheamerica.com/m/25_783...et=0&amount=15
HansGrohe Lift 20
http://www.hansgrohe-usa.com/us_en/1...3530353039.htm
Tony
HouseArrest is offline   Reply With Quote
Old 04-30-2010, 07:51 PM   #2
Rewards Points: 177
Use a full port 1/2" ball valve. 3/4" would be a waste with 1/2" lines. I am not 100% sure but you might not have enough flow (gallons per minute) with 1/2" lines. Those type of showers reguire a large flow rate.
Originally Posted by HouseArrest View Post
Hi all
I am looking at the
HansGrohe Lift 20
Tony
paul100 is offline   Reply With Quote
Old 05-01-2010, 07:13 AM   #3
DIY staff
Rewards Points: 7,174
I second what Paul said--Those units need a 3/4 inch feed line. You will be very -very sorry if you don't run 3/4 directly to the mixer.
---Mike---
Old 05-04-2010, 06:18 AM   #4
Thanks for you replies
I am really disappointed. I would have liked to have the body sprays. Are there any alternative methods, short of running new lines that would enable me to install body sprays(The bathroom is on the top floor I have 3 plus a basement and I really dont want to go thought all the trouble of running new lines from the basement to the top floor). Should I just install a shower head with a temperature and volume control and call it a day.
Tony
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
How much improvement upgrade 1/2" to 3/4" Ultrarunner2017 Plumbing 3 03-19-2009 08:41 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
1/2" Self Tapping Valve wbjdmd Plumbing 2 09-17-2006 10:01 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
