Should I Upgrade From Cast Iron To Pvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2012, 07:36 PM   #1
Should I upgrade from Cast iron to pvc
Im at a point in a 1/2 bathroom remodeling project and need advice. This project was to overhaul a bathroom which the toilet was out use for 2 years. The faucet was used regularly. I replaced my subfloor, 3 shut off valves and painted. When I replaced the floor I did not run the subfloor under the cast iron flange to the pipe but instead directly around the outside of it because I cut a hole in the new wood to replace to rotted area around the toilet I have since replaced the wood which should exist under the flange but have not fastened anything down yet because im considering having the plumming replaced from toilet to sewer inlet with pvc and putting a newer style toilet flange. The cast iron flange is just fine after a steel brush cleaning and well intact but does have some area's where parts connect that seem questionable and somewhat corroded. should i consider just keeping as-is or go with new pvc
rookierebel is offline   Reply With Quote
Old 01-17-2012, 07:48 PM   #2
jproffer's Avatar
Rewards Points: 706
Depends on a lot of thing:
Cost vs. Budget (can you DIY or will you have to hire it done?)
Condition of cast iron
Access to old pipe (is the room below finished, etc)
Other "means" - can you get by without this bathroom for a while (guessing so, since you said....what?, 2 years? )
Can it be done in stages? Replace part of the cast iron now...more later....
jproffer is offline   Reply With Quote
Old 01-17-2012, 10:04 PM   #3
how much would such a job cost? Cut cast iron pipe, about 1.5 feet of pvc str8 pipe, 45 degree elbow and then about another 1.5 ft of str8 pvc with a connection to the cast iron pipe. I can do the new toilet flange. The plumming I want to replace is easily accessible in a wreck room
S
T
R
8
p
i
p
e
45 degree pipe str8 pipe to sewer pipe
Old 01-17-2012, 10:11 PM   #4
Rewards Points: 13,456
Not a great idea to ask pricing when anyone ansewering could be from any country in the world and you have no idea what they even know.
Call localy and get pricing.
Old 01-17-2012, 10:14 PM   #5
GirlWithWrench's Avatar
Best guess is piping materials would run about $60 assuming its 4", plus whatever you need for supporting everything. How are you connecting to the cast iron?
GirlWithWrench is offline   Reply With Quote
Old 01-17-2012, 10:24 PM   #6
When a carpenter did our other bathroom he connected a rubber boot with 4 clamps to secure it to the cast iron portion and str8 pvc pipe. I have a picture of the setup but have a problem uploading it. I read that you can use a sawzall with a 8 inch 18 tpi blade to cut the cast iron but I know if I mess anything up it could be costly so I know not to get ahead of myself.
Old 01-17-2012, 10:24 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 994
Will cost you about, $276,6567.53 permit extra.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-17-2012, 10:42 PM   #8
whoa!
Old 01-17-2012, 10:45 PM   #9
Are you hiring?
Old 01-17-2012, 11:03 PM   #10
Don't believe everything you read. My Dewalt wouldn't do it in a time span measured in minutes not hours, although I've heard a Milwaukee will from a couple of people. You can rent a ratchet snapper or if you have room to get in there, a grinder with a cutoff wheel works great.
Do use 4 clamps on the rubber. If I have to use one of those on a horizontal, I also put a friction clamp on each piece, and run threaded rod through both sides, with fender washers and nuts on the ends past the clamps. When you tighten everything down real good, it all but eliminates the possibility of the pieces pulling apart over time.
Live Free, Work Hard
Old 01-17-2012, 11:16 PM   #11
Even if the cast iron is fine, considering the job would be simple and easy to get at, is it worth going with pvc at this stage of my remodel?
Old 01-17-2012, 11:26 PM   #12
If you have the time, and its all wide open--if it were me, I would. Put down some new subfloor around the toilet with a zillion screws, a nice new closet collar and new pipe as far as you can reach--once you finish it all up, you won't have to touch it again as long as you are in the house, and everything will be rock solid. No leaks, no cracking tile, etc.. But if you just want to be done, let sleeping dogs lie and drive on. It'll probably be fine for a while.
Old 01-17-2012, 11:54 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 564
check the fitting joints of your cast iron. If they show signs of leakage consider replacing. Examine the pipe closely for rust color on the outside. This indicates the pipe wall is getting thin and is about shot. Casual observation really doesn't tell you much as the pipe fails from inside out.
I'd really consider plastic if its something you feel you could do. Removing CI pipe does take special tools and is very heavy. You need to take precautions when removing it- the vent stack may come crashing down if not supported.
One nice thing about CI pipe is its quieter then plastic so you may hear water running down plastic pipe.
Old 01-18-2012, 12:05 AM   #14
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
14 tpi does a good job of cutting c.i pipe
plummen is offline   Reply With Quote
Old 01-18-2012, 01:19 AM   #15
I've been on this project for a month already and before I complete the floor and put a toilet on I think I would rather get the CI replaced. Its at least 60 yrs old and the joints do have rust and corrosion around them and the inside of the pipe near the toilet flange certainly has corrosion inside
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
